Re: farmall M...too much fuel?
Posted by DeltaRed on August 30, 2014 at 19:23:20 from (67.40.59.72):
In Reply to: Re: farmall M...too much fuel? posted by R Weld on August 30, 2014 at 18:24:17:
They are super simple.Just loosen the screws and lift apart.. look for a float dragging on the side;a hole in the float;the pin holding the float come loose;the float set too high. Something is not letting the needle/seat valve close completely or holding it open.If you have to,buy an 'economy' carb kit. It will have basic instructions,and gaskets.
