Re: Farmall B Clucth drags
Posted by Janicholson on August 30, 2014 at 20:23:53 from (74.60.94.18):
In Reply to: Re: Farmall B Clucth drags posted by gurneejoe on August 30, 2014 at 16:11:02:
Measuring the diameter of the pilot bearing, and the shaft snout will tell you if the bearing is out of spec. It should be no looser than .003" to assure a centered clutch. If you take it apart again, look inside the flywheel to see if the disk is touching the inside diameter of the recess. Jim
