Re: putting starter on F20 with flex plate
Posted by kub6040 on August 30, 2014 at 20:30:09 from (54.87.22.185):
In Reply to: Re: putting starter on F20 with flex plate posted by El Toro on August 30, 2014 at 08:13:21:
Back when these tractors were used some had small gas engines mounted on the belt pulley side crank one and let it crank the other it also give them a few more horse's when needed in the field , May not look correct .
