Re: IH 584 clutch
Posted by Janicholson on August 30, 2014 at 20:37:33 from (74.60.94.18):
In Reply to: IH 584 clutch posted by Glenn from calgary on August 30, 2014 at 19:33:15:
Unscrew the fitting and probe the hole to remove as much clotted grease as possible. Then use carb cleaner to to rinse out even more. (protect the paint from carb cleaner) Pump grease through the fitting when it is not installed. Install it and grease the fitting. Jim
