Re: 806 Electrical problems
Posted by Janicholson on August 30, 2014 at 20:47:50 from (74.60.94.18):
In Reply to: 806 Electrical problems posted by Darald on August 30, 2014 at 15:47:58:
The bulb and socket might be able to be cleaned and a light coat of corrosion inhibitor put on the connections. If it is rusty and trashed, replace it. Many on line electronics distributors have the lights and fixtures. Make sure it is a filament bulb, and not a diode. It should be the same current draw as a marker light. Be sure the fixture is not self grounding, it needs two isolated leads to the bulb to work. The wires going to the bulb are not connected to ground through the bulb, but through the regulator. Jim
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
