Re: 300 lp farmall
Posted by Harry Klever on August 31, 2014 at 05:57:31 from (65.23.185.129):
In Reply to: 300 lp farmall posted by rick deere on August 30, 2014 at 19:10:10:
check the serial number, if it doesn't have a cs on the end, it's a add on Lp attachment, the C is for a factory Lp, and the S is for live Power take off, and i would think, you want that! Chances are it's got a Ensign brand fuel system. and If u have to take the regulator or carb apart, have a sharp knife like they sell at the arts and crafts store to cut the the old gaskets away from the metal, gaskets are hard to come bye. This is a two man job to help hold the item to save the gasket. then get yourself a tube of Brylcreem, hair groom and that will soften the old gaskets,and your back in business.
