Posted by SDE on August 31, 2014 at 07:34:39 from (69.179.11.129):
In Reply to: Watery Oil Super C posted by Wheaty on August 30, 2014 at 16:16:52:
If you drop the oil pan to check which cylinder has the leak, you will need to check if the leak is from the sleeve/block connection or if the coolant is coming down the inside of the sleeve. I have a sleeve out of my tractor right now and the leak was actually a crack in the head, and the coolant was coming down the inside of the sleeve, past the rings. I pulled he sleeve for NOTHING. What a waste of time. Instead use a piece of toilet paper to wipe the inside of the sleeve and then put dry paper back in it to see if it gets wet from coolant slipping past the rings.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
