Re: starter motor will not stop running
Posted by homebre973 on August 31, 2014 at 10:55:02 from (24.106.196.254):
In Reply to: starter motor will not stop running posted by old on August 31, 2014 at 09:02:53:
I didn't mention that I did that after I wiggled some of the wires. When I took the wire off the solenoid and turned the ignition switch, it did not start. When I put it back on the solenoid, the starter motor spun but nothing happened. The sound had changed also. It seemed like the starter was turning, but nothing was turning in the engine. I put the tractor in gear and turned the ignition, the starter turned but nothing else happened.
old said: (quoted from post at 09:02:53 08/31/14) Put that meter away and use the simple troubleshooting way I tell you. Take the small wire off the solenoid. The turn the ignition on making sure it is out of gear. Touch that wire back on the solenoid and if the starter turns the ignition switch is bad or you have a short and just reaching in and feeling will not find a short you have to look with your eyes and see every thing which I know is not easy to do. Meters can and do give false reading at times when it comes to volts
This post was edited by homebre973 at 11:27:46 08/31/14.
