Re: farmall M...too much fuel?
Posted by GordoSD on August 31, 2014 at 16:08:49 from (216.106.249.32):
In Reply to: farmall M...too much fuel? posted by R Weld on August 30, 2014 at 18:08:32:
You voided any carb warrantee when you removed the device (sediment bowl) that insures the carb won't get contaminated with debris from the tank. Why did you remove the sediment bowl anyway?.
What happened to the original/old carb?
Rubber lines don't work well in an engine fire.
