Re: behlen power steering
Posted by farmall34736 on September 01, 2014 at 10:18:35 from (184.4.137.168):
In Reply to: Re: behlen power steering posted by tjv on August 31, 2014 at 19:37:14:
Thanks for your reply. I left the pressure gauge between the regulator and power head. Pressure reading was very low and sporatic to the right 150-200psi to the stop and back to netural. Gauge read 0 at netural.It was 0 to the left stop and back. Holding against the lf. or rt. stops made no difference in readings. I replaced all o rings and frt seal. I removed the hi pressure hose at the power head and the spool was centered in the hole. The tractor has quick hitch and will lift the rear wheel off the ground on down draft. I mentioned pressure reading is 950-1000 psi full throttle
