Thanks for your reply. I,m confused about "holding the lever against the remote". I left the pressure gauge between the regulator and power head, gauge reads 0 at netural, gauge reads sporatic 100-200 psi to the rt. to the stop and back, gauge reads 0 to lf. stop and back. Holding against the stop lf.or rt. makes no pressure change. I replaced o rings and frt seal. I removed the hi pressure hose at the power head, the spool was centered in the hole. The tractor has quick and will lift the rear wheel on down draft. Pressure reading is 950-1000 psi full throttle.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
