Re: Tractor not starting
Posted by old on September 01, 2014 at 11:54:30 from (209.86.226.61):
In Reply to: Tractor not starting posted by Calf creek ranch on September 01, 2014 at 11:18:17:
As Jim says more info so we can help you help your self and also maybe keep you seeing. If it is a 12 volt system using 2 6 volt batteries in series good chance the batteries them self are causing the problem due to being dead so you have to give them time to charge up when your jumping them.
If 2 6 volt batteries in pairral (sp) you got lucky they did not blow up in your face which can cause a guy t go blind from acid burns of the eyes
