Re: Two questions - Farmall H
Posted by Bob in wc Ia. on September 01, 2014 at 14:35:07 from (173.20.53.115):
In Reply to: Re: Two questions - Farmall H posted by bassmasta76 on September 01, 2014 at 11:45:35:
bsasmasta
Looks like your definitely going to have to repair
or replace that shaft. I would put a sleeve on the
shaft on side towards the engine that measures
5/8".Then bore your housing to 5/8. May have to do
a little light honing to get a nice fit. the seal
can be carefully pried out. Make sure to get all
of the old shell out. Then replace with a new 5/8"
x 1" seal. On the other end of the shaft , you
could build up as I mentioned yesterday. If I can
be of any more help just ask, or call me .phone:
712 792 3065. Bob
