Re: Tractor not starting
Posted by JRSutton on September 01, 2014 at 16:48:08 from (71.174.108.252):
In Reply to: Tractor not starting posted by Calf creek ranch on September 01, 2014 at 11:18:17:
Others have pointed out the reasons to be cautious - but, if we assume you know what you're doing with the batteries...
... I have to say that I constantly see people not give much thought to their jumper cables or how well those cables are attached. So I'd start there.
If the dead starter doesn't kick right over - (and you have no reason to believe it's faulty) you're most likely doing something wrong with the cables.
First - if you don't own GOOD HEAVY jumper cables (expensive), throw them in the trash and get good heavy ones. Worth every penny.
Then when connecting the cables - you have to get a REALLY good bite on whatever you're connecting them too - it has to be CLEAN metal to metal contact. No corrosion - wire brush it if need be.
Taking care to do it right makes and ENORMOUS difference on how much cranking power you get to the dead motor.
