c301 timing problem
Posted by JBH on September 01, 2014 at 17:37:19 from (76.18.174.15):
I am in the process of putting a 301 in my 460. I have it
installed but will not run when timed correctly. I have put #1 tdc
checked timing marks on the cam gear and crank gear and
there meshed together with the marks perfect and the rotor
button is pointing towards #1 cylinder . The firing order on the
block 1-5-3-6-2-4 distributor turns ccw. I hook the wires to the
cap nothing . I pulled the distributor out and rotated 180
degrees it hit and run changed plugs around to smooth it out .
The tractor will start and run this way! I am at my wits end with
this thing. I have put a silver diamond head on it also and it is
firing out the cap on all six wires . Nothing about it makes
sense . If any one has any ideas I sure would appreciate it.
