Posted by jimb2 on September 01, 2014 at 18:24:52 from (99.241.118.87):
In Reply to: 444 international posted by Mogster on September 01, 2014 at 17:52:35:
Hi, there is an isolator valve at the right front of the seat that turns off 3 pt and diverts to remote hydraulic outlet if one is installed. The valve at left front of seat is push in and turn to reduce hydraulic flow to 3 pt from 6 to 3 gpm. Fluid level can be checked by large pipe plug behind the seat on top of hydraulic housing. Correct level is when you look in the hole there is a shelf visible and fluid should be above shelf.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
