Re: Succesful Farmall M 12 volt conversion (lots of pics)
Posted by rankrank1 on September 01, 2014 at 21:06:49 from (198.228.228.167):
In Reply to: Succesful Farmall M 12 volt conversion (lots of pics) posted by rankrank1 on September 01, 2014 at 18:19:41:
I considered cutting pipe/tubing spacers (and I may yet). The nuts provide adjustability if I need to tweek my belt alignment. Everything is double nutted at every location which leaves very little all thread exposed on the cantilvered end. Suprisingly the double nuts help with the strength factor since so little all thread is exposed on the cantilevered end. It is very solid. Additionally this is true 8mm all thread instead of 5/16" size. The 8mm is a whisker bigger and the threads are finer so the threads are not cut as deep which makes the 8mm all thread slightly stronger than traditional 5/16" all thread.
This post was edited by rankrank1 at 21:07:25 09/01/14.
