Re: Farmall A - firing order [hooking up missing plug wires]
Posted by gdtractor on September 01, 2014 at 22:04:26 from (99.122.16.2):
In Reply to: Re: Farmall A - firing order [hooking up missing plug wires] posted by MM_TX on August 21, 2014 at 15:32:41:
Hi again .. (sending to several to make sure I
get it right - ha!)
Okay.. I thought I had the mag on okay - BUT the
top bolt was out and bottom loose.
So I just guessed and with the proces above . the
rotor was pointing near or at #1 cylinder. After
getting carb and manifold on .. etc .. and new
gas line etc ..
I tried to start it by pulling it a little ways it
did fire .. a few times .. no consistent - and
not very often ..
Now I am wondering if I omitted getting the timing
correct when I put it back ..
Question-what is the basic rule to set the timing
if everything "looks good" as I explained before.
I didn't look at the points or anything yet so
this may be a premature question! does it have a
condensor ? can I test the coil .. I am getting
spark but not sure if it is out of time or if
spark is intermittent ..
What would you suggest ? Please .. Gary
PS .. the carb flooded twice when I was pulling it
.. later the neighbor pulled me about a half mile
.. thx Gary ..
Farmall A ...
Today's Featured Article - The Great Escape - by Dave Hollrah. It all began Monday with a little baling of second crop on the lake shore field, and as I drove out past my sister and her hubby's place, this small calling sound could be heard from the general direction of their manure pile. Out of the yard, over the cows and bale piles, through the dozer piles, poplars, and brush, out onto the ditch grade road, past the noisy 6.2 diesel engine pulling my well traveled Suburban along. Well it sure didn't take me long to figure out what it was because I alrea ... [Read Article]
