(Sending to several to make sure I get it right - ha!) Okay.. I thought I had the mag on okay - BUT the top bolt was out and bottom loose.
So I just guessed and with the proces above . the rotor was pointing near or at #1 cylinder. After getting carb and manifold on .. etc .. and new gas line etc .. I tried to start it by pulling it a little ways it did fire .. a few times .. no consistent - and not very often .. Now I am wondering if I omitted getting the timing correct when I put it back .. Question-what is the basic rule to set the timing if everything "looks good" as I explained before.
I didn't look at the points or anything yet so this may be a premature question! does it have a condensor ? can I test the coil .. I am getting spark but not sure if it is out of time or if spark is intermittent ..
What would you suggest ? Please .. Gary PS .. the carb flooded twice when I was pulling it .. later the neighbor pulled me about a half mile .. thx Gary ..
Today's Featured Article - Talk of the Town: Winterizin Engines - To Drain or Not to Drain? - by Staff. Another great discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "Winter is fast approaching..for a gas tractor should the gas tank be drained and run the engine til the carb is dry or do the gas stabilizer products I've heard of work? (tractor will not be used til spring) any other tips for winterizing?? "
... [Read Article]
Latest Ad:
[More Ads]
