Re: 444 international
Posted by Mogster on September 02, 2014 at 06:51:25 from (208.54.32.190):
In Reply to: 444 international posted by Mogster on September 01, 2014 at 17:52:35:
The diverter valve is installed on this tractor.When I turn it the three point does not raise, probably going to pull the plate off that is under the seat. When fluid is diverted to the remotes and you move the remote lever you can here pressure build and rpm drops. Nothing with the three point hitch. I think some linkage is disconnected in side. Thank you for your help.
