Re: IH 806 or 856?
Posted by Janicholson on September 02, 2014 at 11:45:40 from (199.17.6.24):
In Reply to: Re: IH 806 or 856? posted by pilot199 on September 02, 2014 at 10:23:57:
Dual battery 12v system.
The TA is approximately 33% speed reduction using multi plate hydraulic clutches for direct drive and to prevent freewheeling on slow down (not a speed reducing device except under load). The low range is held from slipping using a one way clutch. They are reliable and make the difference in operation. Some last 10,000 hrs. some less. Shift the lever rapidly when going either to direct or to TA reduction. They are not babied into position. Jim
