Re: 454 brakes
Posted by 495man on September 03, 2014 at 12:57:41 from (24.137.107.69):
In Reply to: 454 brakes posted by longear on September 03, 2014 at 08:06:48:
Each brake pedal operates a master cylinder under the dash, hydraulic lines activate the wet disk brakes inside the axle housings.
If the brakes don't work it's usually because they got air in them. You can bleed them with the bleeder screws on eash axle side (under fuel tank)
There are lots of posts on YT on how to do this.
