With a magneto the rotor will not line up until the retard mechanism has released. Otherwise it will stop before getting to the correct position. You should hear the retard click as it releases.
If you rotate the engine backward the rotor will line up correctly since the retard will not work while rotating backward.
Today's Featured Article - Talk of the Town: Winterizin Engines - To Drain or Not to Drain? - by Staff. Another great discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "Winter is fast approaching..for a gas tractor should the gas tank be drained and run the engine til the carb is dry or do the gas stabilizer products I've heard of work? (tractor will not be used til spring) any other tips for winterizing?? "
... [Read Article]
Latest Ad:
[More Ads]
