Re: M carb.
Posted by Janicholson on September 03, 2014 at 18:23:59 from (74.60.94.18):
In Reply to: M carb. posted by Robertw on September 03, 2014 at 18:09:44:
Wirh number drills (not fractional!!) put bits in the main jet hole until you find its real size (just fits) Then use the next sixe larger for the first "enlargement". It takes very little increase to change the mix radically. The Venturi can be changed out to a larger size. from a 450 carb I think. Jim
