Re: Farmall M Stops moving/PTO while mowing
Posted by Trevor H on September 04, 2014 at 12:22:11 from (70.209.0.43):
In Reply to: Farmall M Stops moving/PTO while mowing posted by Trevor H on August 13, 2014 at 18:36:53:
Alright.... I have installed a new clutch and pressure plate through the belly pump hole...the tractor still acts the same way as before. If I try and shift into 5 gear after the tractor stops moving/mowing it grinds..... I can shift 1-4 with out any issue
Also looked at the counter shaft it is not spinning during the time the tractor is acting up.
So now we know the issue is inside the transmission. Where should I be looking to find the problem...
Thanks again !!!!!!
