Re: Challenge with Clutch on Super A
Posted by rustyfarmall on September 04, 2014 at 14:13:24 from (208.126.186.41):
In Reply to: Challenge with Clutch on Super A posted by henhawk1969 on September 04, 2014 at 12:36:38:
Get the tractor out into an open area. Put the tranny into 4th gear, and while holding the clutch pedal down, start the engine. Naturally the tractor will start moving. Keep holding the clutch pedal down, and start riding the brakes. If that doesn't shake it loose, then it is time to split the tractor. The clutch disc is rusted to the flywheel. All you need to do is break the rust loose.
