Re: 53 Super C - Removal of Transmission Filler Plug
Posted by clint s on September 04, 2014 at 15:36:24 from (67.242.45.169):
In Reply to: 53 Super C - Removal of Transmission Filler Plug posted by mkirsch on September 04, 2014 at 13:08:55:
I guess you could add weld to short 3/4 adaptor/extension and then grind to fit. You also may be able to stick a washer or something in there to take up the slack. I never had an issue with one either though. Honestly when I took the one off my 200 last it was just a little tighter than finger tight and it had been a loooooong time. We have had the tractor for over 40 years that I know and my dad said he never remembers changing the rear or transmission oil ever. Oil was not that bad a little water, but thick and nasty.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
