Re: 350 running rich
Posted by pete 23 on September 04, 2014 at 18:56:42 from (173.87.12.198):
In Reply to: 350 running rich posted by GordoSD on September 04, 2014 at 10:00:10:
Couple of things here. If you truly bottom the load adjusting screw, the engine will stop running. All fuel, low idle, high idle, full load or whatever has to go through that main jet under the load adjusting needle. The main jet is normally a fixed size on that Super H and once you turn beyond about 3 1/2 turns open, it will not restrict the fuel at all. Turning it five turns like recommended for full load is to guarantee you are not restricting the flow. If someone has oversized or installed larger jet then it is possible to overfuel. In that case, running at full throttle , no load, turning in load screw until engine starts to lean out will would be the action to take. Then you can back it out in small increments , like 1/4 turn at a time until you get the results you want. Fuel level will effect the less than full load fuel consumption due to the difference in the point that the main metering nozzle starts to uncover the air bleeds in the nozzle. The best way to check fuel level is to take out the drain plug on carb, install a barb fitting with plastic hose and holding the hose up along side of carburetor, the fuel level should stabilize at 5/8th inch from top of bowl on that carb with engine NOT running.
Today's Featured Article - The Great Escape - by Dave Hollrah. It all began Monday with a little baling of second crop on the lake shore field, and as I drove out past my sister and her hubby's place, this small calling sound could be heard from the general direction of their manure pile. Out of the yard, over the cows and bale piles, through the dozer piles, poplars, and brush, out onto the ditch grade road, past the noisy 6.2 diesel engine pulling my well traveled Suburban along. Well it sure didn't take me long to figure out what it was because I alrea ... [Read Article]
