Re: regulator question
Posted by George Marsh on September 05, 2014 at 05:07:23 from (192.182.63.238):
In Reply to: Re: regulator question posted by George Marsh on September 05, 2014 at 04:42:13:
Got to thinking, it possible your problem may not be dirty contacts, instead the spring tension is too much. I've bent the tabs holding the spring to provide less tension. Also, is you put a piece of paper between contacts, it would keep the contacts from grounding the fields, then you would use just the wire wound resistor, limiting the current, preventing overcharging. Use a voltmeter if you plan to bend tabs. The last 12v regulator I installed the voltage went to 17 volts and the NC contacts still didn't open.
