Re: CUB CADET MODEL 72
Posted by DR. EVIL on September 05, 2014 at 08:59:04 from (70.194.166.237):
In Reply to: CUB CADET MODEL 72 posted by henryv11 on September 05, 2014 at 06:19:51:
On the underside center of the tractor there's a threaded rod that runs from the clutch pedal shaft to the clutch release lever that pulls the throw-out bearing back from applying pressure on the clutch plates. There's a small arm, maybe 3/4 inches wide and 4-5 inches long that presses on the safety start switch. The switch itself is mounted on a cross piece spot welded inside the frame of the tractor, the switch itself towards the back of the tractor, the plunger towards the front.
There may be a bottom frame cover that needs to be removed to see the safety switch.
