F20 pressure plate finger adjustment
Posted by SDE on September 05, 2014 at 14:25:04 from (69.179.29.109):
The diagram shows an assembled unit. Is the 3 and 7/16 the height of the fingers when it is assembled? Or is it to be measured when there isn't any pressure on them? With the pressure plate sitting by itself the height was 4.103. If I assemble it the fingers will not be extended as high, but how do you measure it when there is a step in the flywheel and a clutch disc in the way.
Thank you
SDE
