Re: New Shop
Posted by RTR on September 05, 2014 at 15:00:32 from (216.226.179.180):
In Reply to: New Shop posted by sflem849 on September 03, 2014 at 17:42:55:
I have thought of the idea of having a large sturdy workbench I could get to from 4 sides made from either steel or wood (heavy duty being the key). Then mount or weld a truck type reciever hitch socket to the bench and build mounting plates for various tools such as a bench grinder, vice, small drill press, tabletop extension, and you could make a mounting plate for various components of the tractors when rebuilding them such as the touch control unit. By doing this, you could have a place to mount different tools and be able to remove them to keep your area "clean" and maximize space. Something like this picture.....
third party image
