Posted by rustred on September 05, 2014 at 18:27:58 from (74.214.152.80):
In Reply to: 400 rear wheel posted by Fudd on September 05, 2014 at 17:55:13:
well don"t know what this rocking back forth is. if you don"t have them tightened evenly they will have some wobble. all you have to do is make sure all clamping surfaces are clean and use never seize on the threads. then just tighten the bolts in a star sequence lightly. not just tightening the rim down in one spot. that will put it out of whack right there. I just give them 3 tightening sequences and have never run into a tire wobbling. basically the rim cant really get too much out of true cause it is pressed against the hub and the clamps are just holding it there. and also when you push the tire and rim onto the hub you jack up the tractor and the rim basically falls into place.
Today's Featured Article - Field Modifications (Sins of the Farmer) - by Staff. Picture a new Chevrolet driving down the street without it's grill, right fender and trunk lid. Imagine a crude hole made in the hood to accommodate a new taller air cleaner, the fender wells cut away to make way for larger tires, and half of a sliding glass door used to replace the windshield. Top that off with an old set of '36 Ford headlight shells bolted to the hood. Pretty unlikely for a car... but for a tractor, this is pretty normal. It seems that more often than not they a
... [Read Article]
Latest Ad:
[More Ads]
