560 head gasket
Posted by Brad Vaughn on September 05, 2014 at 19:17:53 from (75.106.120.59):
Was working on a 560 gas tonight and was adjusting the valves. Noticed that a couple of the push rods were messed up and had a parts tractor that I could replace them with. When removing the rocker arm, I realized that they were also the head bolts. I should have drained the antifreeze down but did not know at the time. Put everything back together and retorqued the head bolts. I ended up with antifreeze in the oil so I drained the oil. My question is do you think the head gasket will reseal, or do I need to put a new one in before I fill it up with new oil. Thanks
