Maybe able to see what the problem is through the belt pulley gear box opening, but if the constant mesh gear (front gear on the lower shaft) is bad or anything on the bottom like a key or keyway failure or broken shaft. Transmission top has to come off and enough disassembly under tractor up through the center housing or a transmission split to remove the transmission input shaft with housing.
Normal for gears to grind when trying to shift into 5th without depressing the clutch pedal. If it grinds going to 5th when the PTO stops turning that indicates the transmission input shaft is still turning. If its turning the failure is narrowed to the input gear teeth driving the constant mesh gear or constant mesh gear or on lower shaft as mentioned above.
This post was edited by D Slater at 08:12:26 09/06/14.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
