Re: loboy problem
Posted by David Lampman on September 06, 2014 at 09:00:58 from (69.54.29.239):
In Reply to: loboy problem posted by charlie M on September 05, 2014 at 16:43:00:
Maybe the starter bendex is stuck? If that's the problem, just loosen the starter bolts enough to move the starter out about an inch and it should release. My Super A does this once in a while.
HTH
