Re: Farmall M Stops moving/PTO while mowing
Posted by Owen Aaland on September 06, 2014 at 17:50:44 from (216.47.34.49):
In Reply to: Farmall M Stops moving/PTO while mowing posted by Trevor H on August 13, 2014 at 18:36:53:
To remove the transmission counter shaft:
Remove the LiftAll pump assembly.
Remove the drive shaft coupler and slide the clutch shaft forward.
Remove the cap screw and washer from the transmission input shaft and remove the coupler yoke.
Remove the transmission top cover.
Engage two different gears in the transmission to lock the lower shaft and remove the lower shaft driver coupler/nut.
Remove the transmission input shaft and cage assembly.
Remove the three cap screw retaining the rear top shaft bearing and slide the shaft forward and out of the transmission.
Remove the brake pedal shaft from the rear housing.
Remove the PTO assembly.
Slide the lower shaft back and remove the front counter bearing and cage.
Remove the snap ring retaining the rear bearing to the counter shaft.
Remove the rear counter shaft bearing.
Lift up on the front of the counter shaft and slide the assembly forward and out of the rear frame.
The gears on the counter shaft can be removed with a press.
This post was edited by Owen Aaland at 20:57:52 09/06/14.
