Re: no batt charge - '57 farmall cub
Posted by Bob M on January 02, 2001 at 12:14:49 from (192.232.119.194):
In Reply to: no batt charge - '57 farmall cub posted by frank gumienik on January 02, 2001 at 11:35:56:
Frank - With the motor running at max throttle, run a temporary jumper wire from the "F" terminal on the generator to a good ground. If the ammeter still does not show a good charge, you've got a weak generator. (A healthy generator should charge 12 to 15 amps - about 2/3 full scale ammeter deflection - with the "F" terminal grounded...)
Post A Followup
: Re: Re: no batt charge - '57 farmall cub
