Re: F12 Magneto Installation Question
Posted by Nebraska Kirk on September 06, 2014 at 19:43:52 from (207.91.4.159):
In Reply to: F12 Magneto Installation Question posted by DC Snider on September 06, 2014 at 17:46:42:
See if you can get the impulse coupling off the old mag. Put an impact wrench on the nut and unscrew it. It SHOULD pull the coupler off. If it works, then just send me the coupler and the rebuilt mag and I will swap them. That would save having to ship BOTH mags back and forth. Also remove and send the flat plate that is behind the coupler on the old mag.
