Re: IH 606 w/2000 Loader
Posted by leeedwin9 on September 06, 2014 at 22:10:00 from (208.103.28.125):
In Reply to: IH 606 w/2000 Loader posted by IAtractorKid on September 06, 2014 at 17:57:27:
You didn't mention whether gas or diesel. I had a 606 gas for a couple years and found it underpowered for the tasks that I used it for. It has a C221, same as the 460 utility, but may be rated a bit higher in HP. It would have been handier with the C263 like the 560 and 656 has. In fact, the next generation after the 606 is the 656 utility. --Lee
