Posted by oldiron29 on September 07, 2014 at 11:17:45 from (74.88.13.13):
This is power lift under seat! I have it working with a 2 way mounted plow, It will set and than lift plow as it should. The problem I am Having is the arms seem to go past the stop position. I am wounding if the springs are set too tight. Or should that snap down or up at the end of the 180 degree rotation. Most troulbe some when it is snapped back it hits the plow release so you can not lift it. I need to stop it before that point. anyone else using a power lift on F-12 or F-14 impliments? oldiron29
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
