Posted by KTNC on September 07, 2014 at 17:24:51 from (70.209.128.249):
In Reply to: M brakes posted by KTNC on September 02, 2014 at 13:40:45:
Played with it while jacked up and with cover off, when the brake shaft is not hooked to the pedal adjustment it rotates freely and stops without sticking. When I hook the shaft to the pedal it acts like it can't release quite enough, the shaft is trying to move upwards. Adjusting the pedal all the way out helps some, but then I have no resistance left in the pedal. Screw under pan has been adjusted.
Could brake shaft or pedal adjustment rod be bent and causing this..?
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
