Re: 1948 C low on power
Posted by D beatty on September 08, 2014 at 09:41:48 from (24.12.128.33):
In Reply to: 1948 C low on power posted by PretendFarmer on September 08, 2014 at 05:39:38:
You put new pistons and sleeve in it did you use oversize pistons and sleeves? If you did did you reset the timing for the new pistons and sleeve kit?
