Re: 1948 C low on power
Posted by mkirsch on September 08, 2014 at 11:55:04 from (72.45.143.81):
In Reply to: 1948 C low on power posted by PretendFarmer on September 08, 2014 at 05:39:38:
If the engine is running "wide open" RPMs under load, then the governor is working fine.
How much breakin time has the engine had? Fresh engines will get stronger as they break in.
