Re: Farmall h hydraulic pump removal
Posted by wd9garymn on September 08, 2014 at 17:15:31 from (208.83.206.11):
In Reply to: Farmall h hydraulic pump removal posted by Danh on September 08, 2014 at 16:21:44:
I made 2 rods with a square key welded on to match the hole across the bottom of the pump. Then weld about a foot of bar stock (I used 1/4 x1 flat)on end of each rod so it is in a vertical position and weld or bolt a chain link or an eye of any kind on the top end of bar stock. Use an engine hoist or any other lifting tool with a long strap to hook on the ends of the bar stock. Put some lift tension on it and remove bolts and coupler and pipes and lever -then lower to floor. You need straps long enough to clear steering shaft when lowered. This makes it a safe 1 man job.
