Re: Cub Cadet 102 Won't Start
Posted by Janicholson on September 08, 2014 at 18:48:09 from (74.60.94.18):
In Reply to: Cub Cadet 102 Won't Start posted by dpoc on September 08, 2014 at 18:42:33:
Setting the coil laminations distance to the magnet (Flywheel) is important. if it is out of spec, it will not run. If it is the thickness of a manilla file folder away, it should run. Make sure the ground (if it has one) is clean to the mounting screws. also be sure the safety switches are working, or bypassed. Jim
