Re: Ih farmall 140tractor
Posted by Janicholson on September 08, 2014 at 18:51:36 from (74.60.94.18):
In Reply to: Ih farmall 140tractor posted by Bill140 on September 08, 2014 at 18:17:42:
If the linkage falls off it will stay at idle. caseih.com parts diagrams should show the linkage.
if there is a good connection to the governor, and to the carb from the front of the governor lever (across the front of the engine) then it could be a broken spring in the governor. Jim
