Re: Cub Cadet 102 Won't Start
Posted by wisbaker on September 08, 2014 at 19:05:59 from (173.30.33.15):
In Reply to: Cub Cadet 102 Won't Start posted by dpoc on September 08, 2014 at 18:42:33:
A 102 should have battery ignition, battery, points and coil (at least mine does). Are points gapped? take off the cover and turn it over and see if they're opening and closing. While cranking spray gasoline or starting fluid into and see if it tries to run, if not trouble shoot your fuel system. Check for spark at the plug (if nothing else clamp the plug to the lifting lug hook up the wire and crank it over, should have a nice blue spark, while doing this you can also see if it's got compression (is it pumping air out the plug hole?)
