Re: Re: Help with Hay???
Posted by Bama Binder on January 02, 2001 at 14:49:58 from (206.5.110.200):
In Reply to: Re: Help with Hay??? posted by ltf in nc on January 02, 2001 at 14:21:38:
ltf in nc...thanks for the info...exactly what I needed...2 other questions come to mind...
First is do you fertilize and if so did that figure into the $.75 cost per bale?
Second is that you mention if I find enough horse hay buyers I can increase the price per bale...is it possible to get $2.50 or $3.00 per bale? The owner told me the type of grass, but I can't remember...I'll call him back.
OK...one other question...what are the dimensions of a square bale...I'm going from memory, but I think they are about 18" high by 24" wide by 42" long...is this about right?? There is a 4 stall barn that I can convert to hay storage and I'm trying to figure out if 2500 bales will fit.
Thanks again...I can't imagine anywhere else where you can get so much good info in a matter of minutes...BB
Post A Followup
: Re: Re: Re: Help with Hay???
