IMHO, you need oxy-acetylene. Save the propane torch for sweating pipes and toasting marshmallows. A propane torch won't put out enough BTUs to heat that chunk of metal quickly enough. The heat will have time to transfer into the shaft, which is what you don't want.
Can you get a puller on the drum? I'd use the puller to put a little pressure on it and heat it with the torch until it moves.
You can use all the heat that you want because you're replacing the seal anyway. But, you won't need to get it red hot.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
